Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: tubeless front tires
north puller
12-19-2012 18:33:50
Honestly just thought it would be easier mounting the tires without tubes rather than fight getting them in there.
Robert major
12-19-2012 19:08:01
 Re: tubeless front tires in reply to north puller, 12-19-2012 18:33:50
Ok No problem. I would rather fight once with putting in tubes than spend hours trying to get the tubeless to seal, then end up doing it tubed anyway. If you can get one somewhere, I have a kinda fish wire I use to pull the tube stems through the hole in the rim. That helps no end. when the tubes in you put the tool through the valve hole and screw it on the valve stem Roughly line the stem with the hole then put the last bead on. and fish the stem trough the hole after. Remove tool and then add air. Just be careful not to drop the stem back in while adding air. The other thing is pay someone else to do it then they deal with all the B.S lol. I can do a lot of my own tires. But some days I can't be bothered and give the tire shop a headache instead lol.
Regards Robert
