TractorLinks.com
Re: Super C
north puller
12-19-2012 10:06:10
Cutting down the head makes a good head week and prone to cracking. If you haven't already purchased the rebuild kit, you may want to consider custom high compression pistons if you want more compression that the "kit" pistons will give you.
You might be surprised however at the improvement an overbore and "steped head" pistons will make if the motor you have is stock and worn out.
Scott Blanchard
12-19-2012 14:34:33
 Re: Super C in reply to north puller, 12-19-2012 10:06:10
I am hoping that will be the case. I want to make it as good as I can without damaging the tractor. Unfortunately I have already placed the order. Thanks, I also am from the north, but north east Vermont, You?
north puller
12-19-2012 18:30:01
 Re: Super C in reply to Scott Blanchard, 12-19-2012 14:34:33
A little further north than that.....
Ontario, Canada
showcrop
12-19-2012 18:23:35
Scott, you better build that C right if you are going to compete with the "Red Neck Hippie" up there.
Slow burn
12-19-2012 15:34:05
If I was u I would stop my order cancel the check. If u have problems it's yours. He's not honest. And his kits do not make the power he claims. Just trying to help, not here to start anything.
