TractorLinks.com
Re: Ferguson 50 engine build
VicS
12-17-2012 20:17:03
Thanks I went to Princeton In. The week before and did the best of my life. Won the 3500 and Pulled it out the door in the 4000 then just for a hoot entered the 6 mph and got second. So I figured my luck was over but the next week, got lucky again at Tunica. Yes you need to make it down. Great people and a great building. It is big enough Cale had his sled in the back (you can practice for $10 a hook anytime) also a scales. So when you get in line for your scales you should be within one weight of being right. Vic
Unstylish
12-19-2012 09:57:39
 Re: Ferguson 50 engine build in reply to VicS, 12-17-2012 20:17:03
Vic, I thought about this. I was going to try to put a 318 perkins 4 cyl (should bolt in, I THINK) into a 40 or 50...
VicS
12-19-2012 16:25:05
 Re: Ferguson 50 engine build in reply to Unstylish, 12-19-2012 09:57:39
Is this engine found in a 410 or 510 Combine? thanks Vic
smokeshow
12-19-2012 17:41:04
 Re: Ferguson 50 engine build in reply to VicS, 12-19-2012 16:25:05
Vic the 410 had the AD 4.302 perkins. Same as the 318 but a tad less stroke. I have the 302 in my coop. You have seen it pull.
VicS
12-19-2012 18:22:27
 Re: Ferguson 50 engine build in reply to smokeshow, 12-19-2012 17:41:04
Thanks Guys. I've already learned quite a bit more about Massey's. My friend has bought a new 85 hp Massey. He thinks it has a 276 cu 4 cyl. Is this the same block. ps: it has a turbo. He called me yesterday and said, wouldn't get his new tractor today. The guy delivering it had forgot to check if the doors were shut, and the right one had dissapeared. SSo he hasn't got his new tractor yet. Vic
