TractorLinks.com
Re: fuel needed?
Superih
12-17-2012 05:19:18
Any 110 will run fine. You do not have to worry about quench or cold clearance as the pistons must sit below the deck at top dead center to set static compression at 12:1.
buickanddeere
12-17-2012 13:15:49
 Re: fuel needed? in reply to Superih, 12-17-2012 05:19:18
What do you mean quench doesn't matter?
If you take a little extra time and care instead of just slapping an engine together. Keeping the quench at 25-35 thou will reduce the engines tendency to suffer detonation. The engine will also make more power due to the improved combustion chamber turbulence and mixing.
