| Tractor Pulling Discussion Forum |
Topic: fuel needed?
[Return to Forum]
| Author |
[Modern View]
| Farmall m 421
12-16-2012 08:06:44
68.171.231.85
Looking at building a 421 m. Gonna have 12:1 compression. 450 lp head. 1920 high idle. Cammed for max torque about 1500. Typical 421 type build. What type/octane fuel will I need for this type of engine? What do you guys recomend? VP110? Q16? Something else? Thanks |
| Superih
12-17-2012 05:19:18
12.68.14.211
Re: fuel needed? in reply to Farmall m 421, 12-16-2012 08:06:44
| Quoting Removed, click Modern View to see
Any 110 will run fine. You do not have to worry about quench or cold clearance as the pistons must sit below the deck at top dead center to set static compression at 12:1. |
| buickanddeere
12-17-2012 13:15:49
184.151.61.212
Re: fuel needed? in reply to Superih, 12-17-2012 05:19:18
| What do you mean quench doesn't matter? If you take a little extra time and care instead of just slapping an engine together. Keeping the quench at 25-35 thou will reduce the engines tendency to suffer detonation. The engine will also make more power due to the improved combustion chamber turbulence and mixing. |
| buickanddeere
12-16-2012 11:19:16
184.151.63.216
| What if any quench in that engine combustion chamber? Are you planning on 25-35 thou of cold clearance between the piston and head? That will increase power and reduce detonation . The cam duration can vary the compression pressure from requiring fuel from 87 to 115 octane . Tell you cam grinder what you have as a combo and they will grind to match. |
| Farmall m 421
12-16-2012 17:52:40
68.171.231.86
Re: fuel needed? in reply to buickanddeere, 12-16-2012 11:19:16
| A cam that would allow me to run 87 octane fuel would have overlap to the point that it would barely even run at 1500 rpm. If I want max torque at 1500 then I am going to have short duration and very high cylinder pressure. I want to know if I can run something in the 100-105 octane range, 110, or do I need something better like Q16? 87 aint gonna do for this. |
| ss409
12-16-2012 19:32:48
72.53.194.237
Re: fuel needed? in reply to Farmall m 421, 12-16-2012 17:52:40
| 110 did just fine at 300psi cranking psi, under full load, at 180 degree temp for 3 minutes on dyno. |
| Farmall m 421
12-17-2012 02:48:20
68.171.231.80
Re: fuel needed? in reply to ss409, 12-16-2012 19:32:48
| Thanks. What brand? VP110 or something else? |
| ss409
12-17-2012 07:36:12
72.53.194.237
Re: fuel needed? in reply to Farmall m 421, 12-17-2012 02:48:20
| vp works fine. you was talking about cams there,,,, i dare ya to start with a 450 cam grind. if ur turning 1500 n under rpm, in my experiences, the 450 cam grind did very good in my engine. itll lug clear down to under 1000rpm n still chug out triple digit power. try it as a baseline n work ur way up. |
| Farmall m 421
12-17-2012 09:09:27
68.171.231.85
Re: fuel needed? in reply to ss409, 12-17-2012 07:36:12
| Do you have the stock 450 cam specs? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
