john deere 60 power block head gasket
(quoted from post at 13:53:56 12/15/12) will the stock head gasket from john deere work on a power block.
Yes, make sure you have both block and head surfaced before installing. O'Relleys carries one for about $25.
As JD B Puller said, go to O'Reillys. Ask for a Fel-Pro 7744SBX. They'll have to get it from the warehouse, but should have it in a day or 2. Install with metal side toward the block after spraying with your favorite brew (Copper coat, aluminum paint, etc). I don't use lead washers anymore, but suit yourself on that one. Mike
