TractorLinks.com
Re: G705
nos88
12-14-2012 10:10:51
Why? Is it the adjusters above the axle? Mine are too. Thats silly if that is all thats wrong. Do not believe that is a safety issue in my opinion if built strong enough and right. If this is who I think it is, this tractor and setup is just fine!
dboll
12-16-2012 07:05:07
 Re: G705 in reply to nos88, 12-14-2012 10:10:51
it's also silly to have to walk around the pull the rest of the day with squishy pants because the hitch broke and the front end stood straight up! That hitch could easily be converted to use adjuster bolts above and below the drawbar like the U hitch pictured below, pulling off the Farmall wishbone is another accident waiting to happen, NE Nebraska Pullers won't let you pull off of it, atleast not at Norfolk
Jon Aller
12-14-2012 12:25:38
Yes, top mounts for the adjusters. Have personally witnessed two hitch setups like this fail and have the tractor stand up on the tip bars. Luckily the drivers were unharmed.
We don't have a rule against it in our pull.
showcrop
12-14-2012 16:47:18
 Re: G705 in reply to Jon Aller, 12-14-2012 12:25:38
Look at the geometry. The lower attach points are behind the hitch point so a lifting chain has no leverage against those adjusters, which are of very adequate size. I have seen adjusters bent and front tires 8 feet in the air too, but the hitch point was a foot behind the support point and the supports were 1/3 the size of the ones in the picture. This same guy that went straight up had nice retractable wheelie bars and he had them retracted.
