TractorLinks.com
Re: farmall h build
jess r
12-13-2012 17:31:57
Thanks for the info is there alot of block grinding to fit the 5.5 stroked crank thanks again.
H-66
12-14-2012 03:08:48
 Re: farmall h build in reply to jess r, 12-13-2012 17:31:57
You can take quite a bit off the stock rod for clearance so you don"t need to cut so far into the oil galley. Also cut flats in the cam so you keep it strong. 1/2" diameter on the cam is pretty small.
tuckerMAX
12-13-2012 19:50:58
Yes. At 5.125 you have to take the webbing out. Grind the neck out of the oil galley just shy of breaking thru, and cut the cam down to 1/2" thick. With an untouched stock.rod. not to mention small.areas on the pan rail.
ss409
12-14-2012 05:34:20
 Re: farmall h build in reply to tuckerMAX, 12-13-2012 19:50:58
if you cut the rods just right, use a 350 IH rod journal, not a H journal, you can do 5.75 with only notching the cam and the bottom of the cyl walls, and not touch the webbing, or oil gallery at all. good luck.
tuckerMAX
12-14-2012 09:01:52
 Re: farmall h build in reply to ss409, 12-14-2012 05:34:20
ss409 is right, Youd be better off to put some effort in the rods.
