Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Re: case 400 carb
[Show Entire Topic]  [Return to Forum]
dboll
12-12-2012 20:10:17
209.23.168.119
put in a bigger venturi and drill out the load jet if needed
[Reply]   [No Email]
Dodgeit
12-13-2012 16:14:02
99.95.157.81
 Re: case 400 carb in reply to dboll, 12-12-2012 20:10:17
How big does it need to be drilled out? 267ci cam by baker heads lightly massaged
[Reply]  [No Email]
dboll
12-13-2012 16:47:03
209.23.168.151
 Re: case 400 carb in reply to Dodgeit, 12-13-2012 16:14:02
big enough so you can get black smoke, you should have a wire bit set and go a size or two at a time, had to do it to a 400 carb on a 331ci dc engine, treadwell will have venturies, motec told me once that you don't hardly need one, I don't agree with that
[Reply]  [No Email]
Bill88IA
12-13-2012 17:13:16
38.123.14.49
 Re: case 400 carb in reply to dboll, 12-13-2012 16:47:03
Why waste your time dilling one sized at a time? Dill it out to .093 and be done with it. You can always turn the load screw in if it is to rich.
Motec make his own ventuies. Bigger than you will ever get from Treadwell. Motec can built a better carb than Treadwell for about half the price.
[Reply]  [No Email]
mEl
12-14-2012 04:41:43
71.241.105.252
 Re: case 400 carb in reply to Bill88IA, 12-13-2012 17:13:16
Remove the discharge nozzle and see if there is a jet deep down in the carb, if so remove it, drill the main jet adjustment seat just so the taper will still set on it. Leave the jet out of the passage in the carb. Many do not even have it.
Doug, my carbs for big displacement engines are straight wall venturi but I wouldn't recommend that for stock or near displacement engines. Most will start rite up with no choke. If I want high performance info Motec is my man, Treadwell are great people and do a lot of actual manufacturing of obsolete parts and I use them , but due to Matt's work with big displacement pulling engines and feeding them with stock appearing carbs I feel he has the edge in performance apps. Matt taught me over the fone more than I ever knew about MS carbs, he readily shares info.
mEl
This post was edited by mEl at 04:50:02 12/14/12.
[Reply]  [No Email]
dboll
12-14-2012 05:26:46
209.23.168.61
 Re: case 400 carb in reply to mEl, 12-14-2012 04:41:43
i'm not doubting his abilities and we have discussed this but we pull speed limit often at low rpm's until the load starts coming on and I am a believer on having a correctly sized venturi for throttle response, when I talked to them he pretty much said you didn't need much of one which would be ok at higher rpm's
[Reply]  [No Email]
mlpankey
12-14-2012 16:05:11
98.68.171.199
 Re: case 400 carb in reply to dboll, 12-14-2012 05:26:46
As long as the venturi creates 1 psi of venturi effect its sized correctly no matter the venturis shape.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
