Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Honda Civic Rad. in 77???
showdown
12-12-2012 14:13:32
Was reading in a earlier forum that someone had used a rad. from a Honda Civic, said it worked fine. I was wondering what they used to make the inlet and outlet hoses fit, because the rad, is 1 1/8 in and out. The 77 is 1.5 in 1.75 out. Not sure how to make this work? Any help would be great Thanks.
showdown
12-14-2012 14:39:39
 Re: Honda Civic Rad. in 77??? in reply to showdown, 12-12-2012 14:13:32
Hey Showcrop I was unable so far to find the right adapters in the hardware, everthing goes by the 1/4 in, the rad. on the civic is 1/8, so I have to get from 1 1/8 to 1.5, and 1.75. haven't found any thing in the 1/8 size to use, any ideas. Thanks.
showdown
12-14-2012 07:57:09
I would think the 1/18 in. hoses would slow the flow by themselves?
showcrop
12-14-2012 08:17:20
 Re: Honda Civic Rad. in 77??? in reply to showdown, 12-14-2012 07:57:09
I think that it is assumed that you would be using 1.5 and 1.75 hose adapted down close to the radiator.
showcrop
12-13-2012 11:53:44
I used gray plastic barbed adapters from the hardware store, and went to my local auto parts and perused the rack for a hose with the right bend.
johns
12-13-2012 04:36:01
Whats the dimensions of your original rad?
showdown
12-12-2012 14:52:09
would this rad. keep it cool for it size.
Soilfarmer77
12-12-2012 16:48:10
 Re: Honda Civic Rad. in 77??? in reply to showdown, 12-12-2012 14:52:09
Honestly, I'm still building my tractor. However, my thoughts are that if the radiator was built to cool a 150-200hp (or more) car, it should be more than enough to cool my 100hp tractor, especially the way I'm going to be using it.
Soilfarmer77
12-12-2012 14:46:52
I'm running an electric pump, so I just removed the thermostat housing and water pump and welded up new plates/covers with 1 1/8 outlets. I lucked out and found hoses that worked at the parts store.
Jim F.
12-14-2012 07:19:52
 Re: Honda Civic Rad. in 77??? in reply to Soilfarmer77, 12-12-2012 14:46:52
Just so you dont move the coolant through too fast. I removed the thermostat and installed a plate with two 1/2" holes drilled in it to limit the flow.
830 man
12-12-2012 16:38:29
I know of a guy running one on a 4010 jd and it seems to work fine for him. No longer than it will be running down the track i dont foresee any problems.
