Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Calculating Approximate CFM Requirements
the haulin harris
12-12-2012 12:53:45
cubic inches X rpm divided by 3456
north puller
12-12-2012 15:29:22
 Re: Calculating Approximate CFM Requirements in reply to the haulin harris, 12-12-2012 12:53:45
3456 is assuming that your engine is 100% efficient. However, most N/A engines are lucky to be 80% efficient (only moves 80% of the air it acually displaces) and therefore would only require 80% of the CFM. A little more accurate formula would be inches X RPM / 4320.
This post was edited by north puller at 15:33:28 12/12/12.
Mopower
12-14-2012 07:10:47
 Re: Calculating Approximate CFM Requirements in reply to north puller, 12-12-2012 15:29:22
Your explanation is the closest estimate to my understanding. I was curious how some folks figured it, because it sometimes seems to be an afterthought for pullers, as it was on my MM. I'm hoping for some better power from appropriate CFM and 1/8" more bore next year.
436cu.in. X 1716 / 3456 X 80% = 173cfm
I've probably been running 130cfm at the very most.
Superih
12-13-2012 19:58:23
I think you would be surprised at the amount of air required to run these pulling engines.
Copyright © 1997-2015 Yesterday's Tractor Co.
