TractorLinks.com
Re: Late JD B gears wanted NOS ONLY
jd b puller
12-11-2012 17:37:04
Shane,
I had the same problem with mine when I first built it. Just speculating, but I"ll go out on a limb and say I"m probably pushung a few more ponies than you and this has worked for me. It doesnt come out of 3rd gear, the tractor just stops moving and the gear shift doesnt move, right?
make sure you replace the all the bearings on the top shaft 2,12,15 and 24. Mic the shaft and make sure it fits snug on the bearings. Also check your case and make sure it isnt wallered out where the bearings go.
Make sure the shift rail adjustment is correct, and it sits in the middle of the detent. you can also shim the detent springs and grind a little on the shaft to make a little deeper.
Good luck.
jdjack
12-11-2012 18:24:07
 Re: Late JD B gears wanted NOS ONLY in reply to jd b puller, 12-11-2012 17:37:04
Correct me if I am wrong, but it's jumping out of the overdrive side, right?
jd b puller
12-11-2012 19:59:24
 Re: Late JD B gears wanted NOS ONLY in reply to jdjack, 12-11-2012 18:24:07
Yeah, #9 slides into #13 when the shift lever is on the fast gears (3,5,6). move the shift lever to the left and the #9 slides to the right.
Once I did this, my 442 cuber had no other issues up to 5200#.
