We rebuilt the entire transmission including every single bearing, new bushings in the PTO, All shifter forks etc were gone over and properly adjusted, all tolerances were adjusted to spec, every part was scrubbed spotless, all oil holes chamfered, new shifter cup, ball, snap rings and gasket were all replaced on shift lever etc. Case was spotless and rare earth magnets placed in bottom of case. This tractor sees high use!
The tractor still will pop out of third gear when under load.
The transmission drive gear and shaft assembly inlcuding nut part # AB4161R sub #AB3504R or gear only part # B2435R......and the sliding gear shaft drive part #B3613R sub #AB4193R were both substantially worn. We hoped with new bearings it would stay in gear but unfortunately it will not
I am looking for BOTH of these parts NOS ONLY.
The tractor is a 1948 JD B 201000+
"Severely infected"
thanks for your time
"Severely infected"
