Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Camshaft information
1939A
12-10-2012 15:22:40
We are running 10% overstock. Could i retard the if i retard the cam a couple degrees i think the exaust wont be fully closed when it starts the intake side . It runs pretty good just trying to get a little more out of it. Thanks for all the help
buickanddeere
12-11-2012 09:22:24
 Re: Camshaft information in reply to 1939A, 12-10-2012 15:22:40
Retarding the cam reduces low rpm lug and increases peak rpm power. You want to run the cam moderatly advanced to increase low end torque.
north puller
12-10-2012 18:41:13
My 70 cam is timmed at 108. I run 10% over stock also. I would see if you could advance the cam a bit more - say 105 or 106.
My grind has 105 LSA. Engine works good, but could use a little more lug. I don't think that 112 LSA is going to give you what you want.
May want to consider something different. Josh Blackburn or Gary Baker can give you a better cam grind. Rumor is that they worked together developing a cam grind for A/60's.
rumor has it
12-10-2012 18:48:12
 Re: Camshaft information in reply to north puller, 12-10-2012 18:41:13
Speaking of rumors, didn't this motor come from josh?
1939A
12-10-2012 19:37:20
 Re: Camshaft information in reply to rumor has it, 12-10-2012 18:48:12
No this motor did not come from josh i wasnt aware of him when i built this motor from the things i have seen and learned he appears to knowwhat he is talking about. When i get my A together im going to work on my little boys G and i will talk with him. Thanks to all that have giving me advice im still learning
