allis wc motor build
nl00sb
doing a wd motor build for my wc with a 45 crank, wc/wd 4 1/8 over bore piston kit looking for a set of rods that are just just a slight bit longer than the wc rods
Buda rods. 1/8th shorter, but you have to offset grind 3/8ths so it effectively makes the piston go up 3/16 farther
Offset grinding does not push the piston up further.
It pulls the piston down in the block further.
(quoted from post at 21:20:52 12/09/12) doing a wd motor build for my wc with a 45 crank, wc/wd 4 1/8 over bore piston kit looking for a set of rods that are just just a slight bit longer than the wc rods
eres a picxture of the 8 inch leroi rod
