TractorLinks.com
Re: Josh Blackburn
Josh Blackburn
12-08-2012 17:07:56
9 inch with 3 inch pin would be very reliable. Longevity of 8-10 years typically. 1400 includes crank flywheel and driver balancing
algar
12-08-2012 17:14:07
 Re: Josh Blackburn in reply to Josh Blackburn, 12-08-2012 17:07:56
what is the largest bore I can go with a stock block
Josh Blackburn
12-08-2012 17:16:08
 Re: Josh Blackburn in reply to algar, 12-08-2012 17:14:07
Depends what year and which block used
algar
12-08-2012 17:33:43
 Re: Josh Blackburn in reply to Josh Blackburn, 12-08-2012 17:16:08
48
Josh Blackburn
12-08-2012 17:43:46
 Re: Josh Blackburn in reply to algar, 12-08-2012 17:33:43
5.75 will be max reliably. 468 cube. Mid 80's for hp
showcrop
12-09-2012 08:52:47
 Re: Josh Blackburn in reply to Josh Blackburn, 12-08-2012 17:43:46
School me a little here, just curious about why build a 468 cube A when As frequently pull against Gs which can run 825 cubes?
Josh Blackburn
12-09-2012 10:42:05
 Re: Josh Blackburn in reply to showcrop, 12-09-2012 08:52:47
Around here it takes a 470 cube a to run in antique classes. Good tracks and good competition.
zh4020
03-27-2013 08:36:55
 Re: Josh Blackburn in reply to Josh Blackburn, 12-09-2012 10:42:05
Josh- I have a 1952 A. Looking for more power. Was thinking bore and high compression pistons. What work do you do, and a guess on price. Any other suggestions would be great. Thanks.
algar
12-11-2012 20:47:07
Thank you Josh for the info I have some younger JD guys asking me who to use. Back when I had mine it was Schooler,Merfeld.....
