| Tractor Pulling Discussion Forum |
Topic: Re: TSX 67 Carb On A WC Allis
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| wi50
12-04-2012 06:37:01
74.220.10.189
I make a new neck for the manifold. I cut a flange to match the carb, then I take square tubeing and weld on the flange, I weld the inside at a taper filling from the throttle bore out, put it on a jig in the lathe and bore it at a taper.
I cut the neck off the manifold and open up the bottom of the manifold. Then weld the new neck on filling the corners so I can cut a large radius. The larger the radius you can cut, the better.
If your rules would allow it, I would make a billet plate with the carb bore and bolt pattern on, machine the other side at a long taper, cut the bottom of the manifold out and weld this on. But of course it's not going to "appear stock"
Or you can simply grind the flange on the carb down, or build up the one on the manifold if they have to match and shoehorn it on. Bore the neck of the manifold and radius the corners. They won't flow near as well as either of the above methods but it may not matter depending on your head flwo and engine requirements. This is much easier than the other methods, and will support most of the small engines just fine.
The manifolds don't move as much air as the head will in stock form, and that TSX 66<67<666 etc carbs without any work will flow more than the manifold will in stock form but it doesn't take a lot of time to radius the corners off on the carb neck and in the runner. Weld up the back side of the corners to cut a larger internal radius. The larger radius you can cut the better. I fill the top corner of the runner where it turns to go into the head also, it's just a dead spot and one can put quite a bit of fill in without hurting anything, depending on the radius cut on the bottom. It's all about being able to get the signal from the cylinder transfered to the carb. Shape is worth more than size, velocity is a good thing.
I've got to make a half dozen flanges and necks here for guys anyday and do a bunch of manifold work. I can send you a few pictures if you're interested. If I get a chance I'll post a pic of mine. 715-790-1869
This post was edited by wi50 at 06:47:11 12/04/12 4 times. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
