Anonymous-0
what will a farmall 560 with narrow front. a regualr draw bar (NOT fasthitch). and pressed steel with hubs. and pto and hydralics still intact weigh? 18.4-34 tires thanks
I have a 560 set up like yours except mine still has the cast wheels and 15.5 tires,its 5700 without me on it.
thanks for your input guys. im not sure what it weighs now. its all stock but i switching it to a regualar horseshoe drawbar and pressed steel with clamp on hubs. i just need to get into #5500 i weigh 180 lbs. do you think i need to pull hydralics?. or pto?.my original gas tank is full of rust so im thinking about getting a 4-5 gallon tank for under hood. to save a few lbs.also im gonna switch the 560 seat to the ones that on like a h/m farmall should be lighter.thanks!
My 560 with straight drawbar, 18.4x34 IH heavy hubs press wheels, IH weight bracket, and all hydraulics.
5480lbs
