Is there a difference in ring gears?
No, it has the same 13T pinion and 54T ring gear. The difference is in the 1st gear set. The 140 1st gear set is 14:47 vs. the A,B,BN,100,130 that are 16:45.
The rest of the gears in the 140 tranny are the same as the earlier tractors.
Zack
Are you running Big tires?
If you do swap in the 140 gears make sure you use the reverse idler from the 140 and the oil slinger gear too
Not running big tires. Just pulling dead weight so looking for a lower 1st gear. I currently have it tore down for bearings in the trans sounds like a good time to switch. Any body have a 1st gear set for sale?
Wengners in PA has them and maybe JP tractor Salvage in Mo.
I have been looking for a complete trans out of a junker to rebuild.
