Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Farmall m - whats up?
Cliff S
11-18-2012 09:32:53
My SMTA would Change like that too But it was the time the Gov Opened up all the way!
I Changed the Gov Spring to a Stiffer One and it Helped make the Gov Smoove Out and Gained about 2 Hp at 540 on the pto!
Cliff S
north puller
11-18-2012 16:00:14
 Re: Farmall m - whats up? in reply to Cliff S, 11-18-2012 09:32:53
It is not the gov. For the sake of the dyno test, the 281 had a very stiff spring. Likely would give 2500 rpm or higher. I loaded the motor up at part throttle, then opened the throttle up all the way. I then baked off the dyno till rpm's cam up to 700 pto. I didn't want to let it go any higher and didn't feel the need as I run slower than that at a pull. The gov was for sure wide open all the way.
The dist in this tractor has a 40 deg plate in it - could it be something to do with ignition timing and a change in the advance at that rpm? Would a dist with a 30 deg or 25 deg plate be a better choice?
high octane
11-18-2012 17:49:54
 Re: Farmall m - whats up? in reply to north puller, 11-18-2012 16:00:14
north, use stiff advance springs, or lock it up all together like a mag. itll help.
Cliff S
11-18-2012 17:25:22
The More Compression the Less timing advance to Loug well!
I would Try a Distubitor with Less Advance and make Shure it works Smoove on the Advance and not hanging up!
Cliff S
