north puller
What's the real deal with av gas?
I have run some in my tractor and I worked out well. I found that it runs a little bit leaner than regular gas.
I know that it is leaded and has aprox 100 octane.
I think that to prevent vapour lock it doesn't vapourize as eaisly as regular gas.
Some say that it runs very dry.
Some say it is a good fuel to run, and some say that it is garbage.
Just wondering, is the vapourization characteristic good or bad? How much lead does it really contain and is that good or bad? How lean does it really run? How dry does it really run?
What's the difference between av gas lean/rich knock index and gasoline's octane rating?
Av gas is a cheap fuel, but is it any good to use? Is it any worse for deposits than any other leaded fuel? Are there any other reasons that av gas would not be a good fuel to use?
