| Tractor Pulling Discussion Forum |
Topic: plug gap
[Return to Forum]
| Author |
[Modern View]
| bassndeere
11-15-2012 18:57:43
74.196.186.81
As I understand it, a coil just produces enough voltage to jump the gap on the spark plug. Most antique tractors run .020/.025 gap. What if the spark plugs where changed to the newer style of plugs with a setting of .040/.060? If the coil was capable of 40,000/45,000 volts would it produce more voltage? |
| MLPANKEY
11-19-2012 10:45:14
152.85.8.33
Re: plug gap in reply to farmallstrong, 11-15-2012 18:57:43
| Quoting Removed, click Modern View to see If you have the cap spacing hei or ford cap a msd 6 a box and blaster 2 coil on a 16 volt battery will jump a 1/8 inch plug gap if you have good wires. |
| bassndeere
11-16-2012 17:22:44
74.196.186.81
Re: plug gap in reply to bassndeere, 11-15-2012 18:57:43
| Thanks for all the advice and guidance. I have been looking at those spark plug adapters to use the new type plugs, which generally run a wider gap. My ignition system is adequate but could always use an improvement/change. Always looking for a bigger bang. Thanks |
| buickanddeere
11-16-2012 16:54:40
184.151.63.247
Re: plug gap in reply to Willenium, 11-15-2012 18:57:43
| Quoting Removed, click Modern View to see |
| north puller
11-16-2012 09:28:43
68.171.231.80
| | A 40000V coil wil not necessarily (or likely) deliver 40000V. You are correct in saying that the coil will discharge its energy when the voltage reaches the point at which it can jump the gap. But what happens to the rest of that 40000V? What happens is the coil discharges its "energy". This is in the form of an electrical circuit which consists of both voltage and current. Your 40000V coil has 4 times the energy than a 10000V coil. With the same plug gap, they will both discharge at the same voltage, but the 40000V coil will discharge 4 times the energy creating that big fat blue spark. If your old coil will light off the mixture fine, than you don't need a bigger coil, however, if your old coil is just barely up to the task then a better coil may help. A larger gap is not for the purpose of creating more spark energy. You want a larger gap to give more room for the flame front to grow. More spark energy is simply a requirement of a larger plug gap. Idealy we would have .100" gaps with tons of room for the flame to start, but problem is that's too hard to jump and you end up with erratic spark fireing sideways to ground, or jumping within the dist cap as Buick said, fireing out the side of the wires, or arcing at the coil tower itself. Basicly, the higher voltage coil is most likely not necessary, but good insurance if you are buying a coil anyway as a tune up or a 12V conversion. |
| buickanddeere
11-16-2012 08:47:30
184.151.61.61
| A wider plug gap, higher compression and/or exotic fuel requires more voltage to jump the plug gap. Eventually the spark will jump inside the dist cap instead of across the plugs. One more reason why distributors have disappeared from gasoline engines. |
| ED R
11-16-2012 04:45:48
67.8.217.157
| The voltage output of a coil is directly dependent (up to max capability)on the spark plug , condition, gap, and the atmosphere (compression) that it operates in .IE. if a plug requires 3000v, to arc, then that is what the coil produces for that plug, It would be verry rare for all plugs in an eng to fire at the same voltage Heat range will have no, to verry little effect on coil output. It does change the tenperature at which the plug operates , which may have a little effect. That temp range is only an indication of the plugs ability to fire in dirty (oily) conditions> |
| ACbill
11-16-2012 03:59:35
38.123.14.49
| And what good will a hotter spark do? |
| Ole Johnny
11-16-2012 03:39:52
71.28.231.205
| Voltage out put of a coul is dependent on the number of turns or windings in the coil itself. If you use a coil with double the internal windings, you would have twice as much voltage output. If you are trying to get more spark, you can get hotter coils and all coils fire when the voltage to them is interupted and the field collapses so a points set or electronic system will do the same job under normal engine speeds. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
