Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Oliver 880 Gas Intake Manifold
Del Anderson
11-11-2012 17:46:37
Does anybody no where you can get an Oliver 880 or 265 cu. in. gas intake manifold with better air flow. Thanks Del. PH 507-227-7062.
Del Anderson
11-13-2012 18:54:35
 Re: Oliver 880 Gas Intake Manifold in reply to Del Anderson, 11-11-2012 17:46:37
I have decided to use the stock one and just clean it out some thanks for all the replies Del.
high octane
11-14-2012 07:29:55
 Re: Oliver 880 Gas Intake Manifold in reply to Del Anderson, 11-13-2012 18:54:35
ive used 1.45diameter reamers to open up the inlet and all the ports on 88 heads. made it easy and opened em up quite a bit. shoot me an email, ill show ya the tooling Ive used n had good results.
A.P.
11-13-2012 17:15:21
Murphy's offers a better flowing intake manifold if the rules you run under will allow it.
RICHB
11-13-2012 09:54:44
1650 manifold,cut it apart do your work then mate it back together with a jig....only other option is a tubing manifold and not legal most places.
Sassey Massey
11-11-2012 18:03:18
If your rules allow a 88 diesel manifold works excellent and is a cheap buy on ebay
Del Anderson
11-11-2012 18:06:31
 Re: Oliver 880 Gas Intake Manifold in reply to Sassey Massey, 11-11-2012 18:03:18
We set the diesel one on upside down and you half to cut the flange and turn it and it sits way to close to the block for the carburater to fit.
dboll
11-12-2012 09:55:27
 Re: Oliver 880 Gas Intake Manifold in reply to Del Anderson, 11-11-2012 18:06:31
the dsl. manifold would not be allowed in class 1-2-3 at Madison or other places anyway., we already let 310's slip by even though we have rules against them
S.D.L.
11-11-2012 17:56:40
Murphy"s has one, but I"m not sure how much better it flows. You can drill your own mounting holes for whatever carb you want.
Del Anderson
11-11-2012 18:03:17
 Re: Oliver 880 Gas Intake Manifold in reply to S.D.L., 11-11-2012 17:56:40
Im looking for better air flow through the whole manifold.
