Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Re: John deere 730
[Show Entire Topic]  [Return to Forum]
buickanddeere
11-09-2012 19:28:24
216.183.145.233
Head/manifold matching,straight stack, valve bowl cleanup, 830 valves,5 angle valve job. Dry air filter element.Cam re-grind. Late 6X 12 thous 820/830 injector tips. Heavier valve springs.
Maybe 80HP at 1500rpm. Lots of extra torque however at 1000rpm.
[Reply]   [No Email]
Brad Vinkemeier
01-08-2013 19:34:38
174.225.134.83
 Re: John deere 730 in reply to buickanddeere, 11-09-2012 19:28:24
Hey buickanddeere u seem pretty sharp on the. 2cylider diesels i am in the process of overhauling my 730 diesel my question is which valves do u use from an 820 intake or exhust or both but from what i could see is there isn't a whole lot of room to put in an intake valves from an 820 due to being tight by the fire ring or cylinder wall and on the other side its darn close to the injector bore the the exhaust side i think u could put in the bigger valve there seems to be enough room the other question i was wondering about is the injector spray patter on an 820 is 160 degrees versus on a 730 the spray pattern is 140 degrees. I wouldnt put 820 injectors in due to u and may have the possibility of scoreing a piston if im not mistaken the spray pattern has to mach the mushroom top on the top of the piston im wondering since the 820the a longer stroke if thats the reason for the 160 spray pattern
[Reply]  [No Email]
buickanddeere
01-09-2013 12:06:13
216.183.134.197
 Re: John deere 730 in reply to Brad Vinkemeier, 01-08-2013 19:34:38
Which 820?
There was the 67HP 820 with the 80 engine using 10mm pumps and fiveX10 thou 160 degree tips. And pistons with a wide shallow bowl.
The late 75HP 820 used the 830's 13mm pump, 6X12 thou 140 degree tips. Bowl in piston is narrower and deeper.
830 intake and exhaust work just fine in a 730.
The valve bowl shape and valve seats will make or break the conversion.
[Reply]  [No Email]
Brad Vinkemeier
01-09-2013 16:26:53
174.230.192.209
 Re: John deere 730 in reply to buickanddeere, 01-09-2013 12:06:13
Ok i didnt know that about the early 820s and the later ones sorry i was wrong
[Reply]  [No Email]
gtx1967jewison
11-09-2012 20:42:40
174.253.145.92
I run my R to 1500 with only 2 mains & a much longer stroke. I wouldn't batt an eye running it to 1800-2000. rpm REALLY produces results on mine & its ALL unmolested factory parts. A cam & head work alone should give 80 HP from a 730 I'd say? I get 62-64 from the R just spinning it fast & full open fuel rack, k&n filter. That's on the crankshaft via a belt dyno.
[Reply]  [No Email]
buickanddeere
11-10-2012 15:49:09
216.183.145.233
 Re: John deere 730 in reply to gtx1967jewison, 11-09-2012 20:42:40
Volumetric efficiency and thus torque drops rapidly at high rpms with two cylinders due to the small ports.
[Reply]  [No Email]
gtx1967jewison
11-11-2012 05:35:48
174.225.136.217
 Re: John deere 730 in reply to buickanddeere, 11-10-2012 15:49:09
Do you know if 830 valves can be made to fit in an R head? Thanks!
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
