Suitcase Weights
Where is a good place to buy knockoff suitcase weights (perferably like IH suitcase weights)? Needing about 3000lb and don"t want to mess with building homeade weights just want to buy a bunch at once
I can fix you up with steel ones made off 75# IH as a pattern. They are 1" thick and weigh 50# each. Much nicer to handle not being so heavy. 540-890-0240 Located in Southwestern Virginia
If you are around St Louis area call Bill at 314 406 5906.He should have as many as you need 70 lb IH weights.
