Clutch questions Case 700
Dodgeit
Got the tractor split to replace a seal and the clutch disk is almost gone. The flywheel itself has some surface cracks. Whats the best option for replacing whats needed? I assume the flywheel needs replacing, or?
No, they always have cracks. Just take it to the machine shop and get it surfaced. Replace the other seal while you are in there along with the clutch release bearing.
