Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: How do you run alt/gen when water pump is removed?
Nick in MD
11-04-2012 15:40:28
thanks, anyone else got anymore good ideas
baldwin racing
11-05-2012 17:12:01
 Re: How do you run alt/gen when water pump is removed? in reply to Nick in MD, 11-04-2012 15:40:28
machine a bracket with a shaft to hold a bearing free spinning pulley. that sits in the same spot that the stock water pump pully was and leave alt in stock spot? if you dont want to run it underneath...just an idea?
kelly
baldwin racing
11-05-2012 17:14:56
 Re: How do you run alt/gen when water pump is removed? in reply to baldwin racing, 11-05-2012 17:12:01
pulley with a high speed bearing in it....so its free spinning with no drag....
what i ment to say in post above
kelly
E V Ward
11-04-2012 15:50:49
Thats the only way unless you leave it up top with a long belt. I have mine under the bottom and its easy to do that way.
Nick in MD
11-04-2012 17:22:02
 Re: How do you run alt/gen when water pump is removed? in reply to E V Ward, 11-04-2012 15:50:49
thanks for the help guys
H-66
11-04-2012 17:39:04
 Re: How do you run alt/gen when water pump is removed? in reply to Nick in MD, 11-04-2012 17:22:02
I run an electric fan and water pump in my H with no alternator. I got a Yellow top optima battery and good charger with an AGM setting. Charge it the night before the pull and you are good to go.
Nick in MD
11-05-2012 23:23:57
 Re: How do you run alt/gen when water pump is removed? in reply to H-66, 11-04-2012 17:39:04
Having no alt with msd boxes there is still enough battery for a day of pulling?
Eddie Ward
11-06-2012 06:34:08
 Re: How do you run alt/gen when water pump is removed? in reply to Nick in MD, 11-05-2012 23:23:57
I don't think so. If you have a high output fan and do much cranking I think it would kill your battery.
Copyright © 1997-2015 Yesterday's Tractor Co.
