TractorLinks.com
Re: 44 or A
H. DeBruhl
11-01-2012 17:02:47
Massey Harris 44 with out a doubt! I can pull mine from 4500lb through 7000lb no problem. 13.6-38"s and it will spin out every time. Found it pulls best from 5500 to 7k with one set of wheel weights and weights on rear and middle bars.
Hope this helps
MH-JD
11-01-2012 17:22:36
 Re: 44 or A in reply to H. DeBruhl, 11-01-2012 17:02:47
Do you mind saying what you have done to it.
H. DeBruhl
11-01-2012 18:00:25
 Re: 44 or A in reply to MH-JD, 11-01-2012 17:22:36
Sure... New rings, valve guides, two new valves, hotter coil. Had to have the head surfaced to remove light rust where old head gasket was bad. New filter, oil etc... Just a normal service really. Had been stuck for years, would guess 20ish. Runs reg pump gas, 45 degree tires. Around here we pull on mostly clay tracks. Biggest thing I think is I have found the best balance point and let it chug it out in first gear.
Send me an email if you would like to see a video or two, or if you need more info.
