350/175cu rod #
Anonymous-0
Does anyone know for certain what a 175-350 rod # is? I've been told 364912R it says 7/8 wrist pin but also says has bushing. I want the right rods for a 175, not ones that would fit all models h thru 350. Thanks AJB
364912R1 is on the rod. That rod use a regular thin piston pin bushing. Not a adapter bushing like used in previous rods when useing the small piston pin. Without looking I think all the big pin rods have just 5 numbers before ending suffix.
364912R1 was used in C169 gas engines, engine serial # 48045 and higher in a utility tractor and 48049 in a farmall. All C175 used 364912R1.
