4 3/8 pistons
no, youd need longer rods or add a stroker crank. "cut n paste" a set of M rods to the length you need n run it. or, spend 800 or more on custom set that uses stock rods. Talk to Ray at Extreme tractor parts. He will make you anything you need. Also, you need a super m thru 450 block to run over 4.25, but not over 4.38 bore in em. Ms r good to 4.25 bore. good luck.
