Unstyled A slower high range gears
Looking for a set of slower high range gears for unstyled a im running 5mph at quarter throttle in 3rd and am told with slower high range will top out at 5mph if anyone knows anything about them or has a set laying around give me a shout thanks 9892775366
nebraska test says it's 2.5 in first,3.5 in second and 4.5 in 3rd with stock tires my calculator says with 16.9 x 38 tires 1243 rpm will get you 5 in second . if 5 will get it done it would be 2nd for me .
I took the reduction gear and pulley out of a 52 a with 14.9s and allot of rpms mine wont break 5 mph in 3rd gear
Josh I replaced my 36 A gears with 38 gears bout 15 years ago. Don"t remember all the details but had a 38 and took the countershaft and some of the gears and made 3rd and 4th slower. By looking at parts book 410000-450503 had faster gears and 450504 up had slower gears. Lynn
Thats what im looking for as far as speed mine with newer reduction will hit 5mph at half throttle. Looking for part number or parts
Thanks Lynn i appreciate your response i took my 38 trans apart and it had same teeth count as my fast high range trans did they split in middle of 38?
2nd does get it done for me up to 7000 with 18.4's 4 and 5 mph im looking for more options in light classes i have the engine i want the slower high range gears for 3750 4000 4250 4500 4.5 and 5mph in 3rd thanks
Josh I think it was mid 37 the change was made. Looking at parts book some more the difference is the countershaft having 17 and 25 and going to 19 and 25 and the overdrive gear and shaft going from 28 to 26. This only affects 3rd and 4th gears. Lynn
Josh i i have a 38 with the "slow" reduction gears but when i changed from the "fast" or unstyled gears i only slowed down by .5 mph. so with the "slow gears and 15.5s i am running right at 3.8 mph at 1100 rpm in 3rd gear. not sure it this helps you but that is the diffrence in the gears in the same tractor with smaller tires.
