Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Copper head gasket
SPT
10-25-2012 16:02:32
Having problems with sealing copper head gasket on 4.5 bore D 17 Allis, any suggestions?
bassndeere
11-03-2012 19:22:20
 Re: Copper head gasket in reply to SPT, 10-25-2012 16:02:32
Crank her up and get her warm, then torque head bolts/studs. Do this at least 3 times, increasing torque everytime to at least 175 lbs. Then but a load on her. PS. cold she will be over 200 lbs.
Jim Johnson
10-27-2012 05:39:35
Lubbock gasket in Lubbock Tx. makes a gasket with a wire in it and I believe they guarantee it. You can ask Ken Foland about it because I think he was using one.
Jim
ep
10-26-2012 17:02:56
you can get an Isky O ring cutting tool from summit racing and cut a groove in the sleeve to put a piece of wire for your fire ring.I use stainless wire instead of copper wire.Tool is 300$ or so but works great.You will need to practice on an old sleeve or block a couple of times.good luck
wi50
10-26-2012 06:08:15
I alawyse o-ring either the head or the block. Probably easiest to do the head as long as the block deck is flat.
I know there are guys useing composite gaskets on larger bores than that on the Allis and i'd think you can find fire rings and make one from a gasket
oliver80
10-25-2012 20:01:57
I Always Spray Them With Copper Coat And Never Had Any Problems.My Sleeves Are Ringed Also
Ole Johnny
10-25-2012 17:11:32
When I used dead-soft copper head gaskets on my dragster, I had to O ring the block and head so they woudl work. Also it is necessary to use gray silicone to seal the water passages. If there is a composit head gasket for your application, I think that would be much better.
Eric segaline
10-25-2012 17:04:33
deck head and block and fire ring it
SPT
10-26-2012 06:17:39
 Re: Copper head gasket in reply to Eric segaline, 10-25-2012 17:04:33
Thanks for the input.
MLPANKEY
10-26-2012 08:11:39
 Re: Copper head gasket in reply to SPT, 10-26-2012 06:17:39
SPT said: (quoted from post at 06:17:39 10/26/12) Thanks for the input.
Stainless .024 wire place in groove on sleeve
This post was edited by MLPANKEY at 08:12:17 10/26/12.
