Gonna need a lot more info.... Assuming a IH, H,M,350'450,460,560
Also what is compression, bore and stroke ( I personally think there is more power to gain by stroking than boring)...
What head is being used as some flow better than others, max RPM
That should be able to get some ideas going, maybe even stir the pot a little :wink:
4.310" bore and 7" stroke for a farmall 450, with 11:1 compression and a few "add ons".
Would the "add ons" be a cam and roller rockers?
Would this engine happen to use billet rods?
Why don't you ask the guy putting the package together what the power should be.
Then again, engine RPM, carb modifications, and head modifications can have a major impact on an engine when you get that big.
I would guess 90 hp if you keep the carb and head stock.
I believe the seller of the parts has said that his customers have seen better than 110 hp with the right setup.
I can't give you an exact h.p. no. but the engine is reliable if the machine work is done well. we are turning 2800 rpm. be ready to provide lots and lots of air and fuel, she's hungry.We were in the money every where we went last summer.
I usually figure about .25 hp per cu in that makes it around 102 for me . you can only go by what you know so that figure is at 540 pto . it will be a lot more when you take it up rpm 20 percent .
