Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: massey 44
bp4455
10-22-2012 07:13:43
actually there are 2 heads. the 260 head on 44s and the 277 head on 44 specials and 444s. The 277 head has a little better flow and the valve is unshrouded compared to the 60.
C Elliott
10-22-2012 12:28:53
 Re: massey 44 in reply to bp4455, 10-22-2012 07:13:43
Bp, I did notice that the 44 and 444 heads have different part #'s. Are you sure the 277 does not have the shroud? I am not questioning you but I am building a pulling engine and would like to know about the 277 head not having the shroud around the valve. I have heard many stories that only the LP was unshrouded both 260 and 277. I have also heard that all heads are the same and the only difference are the valve seats between LP and gas. I would really like to know 100% positive that the 277 does not have the shroud.
Thanks, Curtis Elliott
bp4455
10-23-2012 05:54:47
 Re: massey 44 in reply to C Elliott, 10-22-2012 12:28:53
i know it is not shrouded like the 260 because dad put one on his pulling tractor. It also appeared to have a slightly shorter combustion chamber to help with compression. I do not know if the 260 lp head is shrouded or not, never seen one. Whatever head you use i would recommend milling it .150", .200 if it has never been milled, masseys need it to get any compression
Copyright © 1997-2015 Yesterday's Tractor Co.
