TractorLinks.com
massey 44
sww011
10-21-2012 11:53:34
What is the best head for a massey 44?
sww011
10-22-2012 09:26:19
 Re: massey 44 in reply to sww011, 10-21-2012 11:53:34
Thanks for the help guys
bp4455
10-22-2012 07:13:43
actually there are 2 heads. the 260 head on 44s and the 277 head on 44 specials and 444s. The 277 head has a little better flow and the valve is unshrouded compared to the 60.
C Elliott
10-22-2012 12:28:53
 Re: massey 44 in reply to bp4455, 10-22-2012 07:13:43
Bp, I did notice that the 44 and 444 heads have different part #'s. Are you sure the 277 does not have the shroud? I am not questioning you but I am building a pulling engine and would like to know about the 277 head not having the shroud around the valve. I have heard many stories that only the LP was unshrouded both 260 and 277. I have also heard that all heads are the same and the only difference are the valve seats between LP and gas. I would really like to know 100% positive that the 277 does not have the shroud.
Thanks, Curtis Elliott
bp4455
10-23-2012 05:54:47
 Re: massey 44 in reply to C Elliott, 10-22-2012 12:28:53
i know it is not shrouded like the 260 because dad put one on his pulling tractor. It also appeared to have a slightly shorter combustion chamber to help with compression. I do not know if the 260 lp head is shrouded or not, never seen one. Whatever head you use i would recommend milling it .150", .200 if it has never been milled, masseys need it to get any compression
LarryM
10-21-2012 21:19:58
The one you got. They only made one for a 44. The varied the compression ratio with the pistons.
Mike in Mn.
10-22-2012 22:13:17
 Re: massey 44 in reply to LarryM, 10-21-2012 21:19:58
I have also read that the comp. was changed with the pistons,not the head. Bought a 44 for pulling last year, ran good, pulled good, comp on all cyls. was only 80 psi. Tore it down last winter, it had 4 inch pistons in it and was in fairly good shape. Found a 4 1/16 conformatic engine kit with domed pistons and took 1/8 inch off the head and only ended up with 145 psi comp, a gain of 65 psi, but The gas engine is suppose to have 120 psi stock with 3 7/8 pistons. What gives?? I think I have a kerosene head or low comp head. I"m going to cc the combustion chambers and change heads this winter. I have a 44 and a 444 head laying around so I will find out if there"s any difference.
