Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: AC puller
[Return to Forum]
dgerth
10-14-2012 07:30:08
63.142.202.118
Looking for opinions plz, What combinations of tractor and engine would be competitive in the 3K and up classes using Allis Chalmers machinery?
Tks for responses ahead of time.
dg
[Reply]   [No Email]
boomer1
10-15-2012 18:55:20
199.120.66.146
 Re: AC puller in reply to dgerth, 10-14-2012 07:30:08
I would get a D-21 426 engine and put it in a WC-I would use a P pump with 15mm plungers and a good 4.1 Turbo---You should be almost unbeatable-unless you run up against a 466 in a C Farmall!!!
[Reply]  [No Email]
dgerth
10-14-2012 21:15:40
63.142.202.118
Tks soo much for opinions! Are we looking at a WC with a WD45 engine or what seems to be the consensus
on this? What, how to build etc?
What say yall?
dg
ps: I was contemplating a WC or WD WD45 combo. Will the combine (Gleaner) engines fit? or what prob will one encounter?
dg
[Reply]  [No Email]
VicS
10-15-2012 18:05:01
70.195.1.90
 Re: AC puller in reply to dgerth, 10-14-2012 21:15:40
With a short chain, a 226 WD45, D17, or a Late Combine engine isn"t enough engine in a WC, WD or a WD 45 gas. They might be if you put a D17 ring and pinion in your WD 45 gas. A WD 45 diesel has the same ring and pinion. The cheapest thing you can do for hp and torque is to stroke your WD 45 engine 1/2 in. Use your rods and pistons. Can get this done for around 500 dollars. I"m talking about using 15.5 X 38 rear tires. We pull a Steel rear WC with fast gears and a 366 engine, will pull 3 or 6 mph in low gear. A lot of guys you pull against will have 400 plus cu in.
[Reply]  [No Email]
bp4455
10-15-2012 06:54:33
70.199.103.129
The gleaner is pretty easy to drop in. you may want to put the stock governor and front cover on the combine motor. def use taller 4.125 pistons to get compression ours is about 12:1 and runs well on 93 octane gas.
[Reply]  [No Email]
north puller
10-15-2012 04:36:55
68.171.231.80
If you are looking for something quick, easy, and cheap, then build a WD45 engine with a .125" overbore kit. Makes 240 cubes. If you don't mind running the "best of the best" as far as fuel goes, then by a WD rebuild kit instead of a WD45 kit. The taller pistons will put compression way up. I haven't got a real straight answer, but seems compression would be in the 12 - 13 range.
[Reply]  [No Email]
dgerth
10-14-2012 21:07:49
63.142.202.118
Thanks soooo much! Are we looking at a WC with a WD45 engine "pumped" ? or what is the best opinion here?
dg
[Reply]  [No Email]
Kip-Utah
10-14-2012 18:52:43
75.169.67.184
I agree WC hand brakes are a plus when it comes to pulling. I find them much more instinctive to use than foot brakes! I have a bias but my choice would absolutely be a WC. We"ve won classes from 3,000-4,500 with ours. If you want to run fenders it"s tough to get down to 3,000 especially with an unstyled tractor. I also like the electric starter on the styled models, but we pull both styled & unstyled WCs and do well with either. Good Luck! Kip
[Reply]  [No Email]
slowsmoke
10-14-2012 07:58:10
70.199.106.153
WC with stamped steel rear end will make 3000#. just add a 45 crank and you're good to go. I have one for sale!
[Reply]  [No Email]
another Puller
10-14-2012 11:06:06
66.75.23.25
 Re: AC puller in reply to slowsmoke, 10-14-2012 07:58:10
what tractor is lighter the styled wc or unstyled wc?
[Reply]  [No Email]
bp4455
10-14-2012 10:23:56
70.199.108.254
i would make a wd on 13.6 or 15.5 38s Mine on 13.6 will just make 3250 class. You could save more weight by getting small front tires and deleting the hand clutch. use angle iron or aluminum for light weight brackets. The problem with a wc is the rearends are geared really high and its about impossible to use the handbrakes in pulling. For engine use gleaner motor and overbore kit.
[Reply]  [No Email]
slowsmoke
10-14-2012 15:07:34
70.194.1.2
 Re: AC puller in reply to bp4455, 10-14-2012 10:23:56
it's VERY easy to use hand brakes pulling. "two handed posi" They are geared fast. mine has 14.9/38's and I run 3.5 mph speed limit. RC ring and pinion would help, or the corn picker 2 speed that's under drive
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
