Yesterday's Tractor Co.
Shop Now View Cart
Re: Farmall m
John 37A
10-09-2012 09:32:23
I am at 65 hp now with a 4" bore, firecraters, cam from ray at extreme and a smoothed 450 gas head. I am just trying to figure if it is worth my money to get pistons made for this spare 450 block that I acquired. I can't really justify spending the money on a crank and rods (or even just a crank) unless I could find everything used. I would just like to be able to pull 2nd gear in the 5500.
10-10-2012 20:26:45
 Re: Farmall m in reply to John 37A, 10-09-2012 09:32:23
4.375" bore stock stroke is 315 cid. Just a quick thought but if you look at the hp to cid ratio and make HUGE assumption that if it were the same then your horsepower would be 82. I have no idea if that is an accurate assumption becasue your flow efficiency changes and your compression ratio changes. Just a thought. What is your carb set up?
