Oliver 310 hp????
6pack
Getting my ducks in a row for another motor...thinking of 4.5 bore and 5.75 stroke on a 310 running 2500 rpm with a custom intake/header...porting and bigger valves.......any guess on HP with this build
While on the subject would anyone share what 4in auto piston there using? Cant seem to find one with a 1.250 wrist pin.
I used Icon which are Keith black forged aluminum....they have .990 wrist pin....I browse summit,and CNC motorsports...should be able to have pin bushings made to work at machine shop
(quoted from post at 08:06:52 10/09/12) Who around here let's u run custom manifolds like that?
Probably will have to keep side shields on!!!! LOL...
Starting a new trend!!! Putting thousands of $$$ in a motor and using a junk manifold is like bolting on a restrictor plate!
Making a mild steel manifold is easier than cutting and welding old cast iron ones....should look similar to stock, jut rounded and not all square :wink:
