TractorLinks.com
Re: 12 volt ssystem on John Deere 2 banger
730d se
10-08-2012 14:27:41
Unless you like replacing the bull nose on the starter and/or the ring gear, it is wise to have it rewound to 12 volts.
Ole Johnny
10-08-2012 15:27:46
 Re: 12 volt ssystem on John Deere 2 banger in reply to 730d se, 10-08-2012 14:27:41
What would cause these failures??
jd b puller
10-08-2012 17:23:26
 Re: 12 volt ssystem on John Deere 2 banger in reply to Ole Johnny, 10-08-2012 15:27:46
If you're replacing the bull nose on the starter you don't have it timed right. It's firing too soon before TDC and at the slower cranking speeds, it's building pressure and kicking back on you.
Pull the starter you have off, clean up the commutator, put new brushes in it and throw 12V at it.
Another thing you can do that will help is to hit the starter with the ignition off, once it's rolling, then hit the key,.
This post was edited by jd b puller at 17:28:49 10/08/12.
Ole Johnny
10-08-2012 19:25:39
 Re: 12 volt ssystem on John Deere 2 banger in reply to jd b puller, 10-08-2012 17:23:26
Thats what I thought Ray,, Thanks for the info..
