12 volt ssystem on John Deere 2 banger
Unless you like replacing the bull nose on the starter and/or the ring gear, it is wise to have it rewound to 12 volts.
If you have a basically stock JD 6V 2-Cylinder..12V will spin it pretty fast...
You might tame it a little by using smaller Battery Cables, for more resistance, to get some voltage-Drop...
I never like to "Jump" my JD "B" with 12V..it spins it over mighty fast..
Ron..
If you're replacing the bull nose on the starter you don't have it timed right. It's firing too soon before TDC and at the slower cranking speeds, it's building pressure and kicking back on you.
Pull the starter you have off, clean up the commutator, put new brushes in it and throw 12V at it.
Another thing you can do that will help is to hit the starter with the ignition off, once it's rolling, then hit the key,.
It's a hand crank now and has too much compression for me to man handle like i did when it was 6 to 1 compressiion. Im changing it to electric start and was concerned about using a alternator and 12 volt battery on it but using the 6 volt starter still. I knowI could get a 6 volt starter but then I would have to have a 6 volt GENERATOR and I dont want that.
I"ve been running mine on 12V for a long time now. No problems. I"ve never had any problems using 12V on 6V starters on anything.
