TractorLinks.com
Re: Flywheel
buickanddeere
10-07-2012 09:47:30
Did you install the taper-loc as per the directions? Never heard tell of a taper-loc coming loose when properly installed. In fact they are a real chore to remove as they get stuck on so tight. If you just tightened the large jam nut once then drove away. Then yes the taper-loc will come loose.
Deerepower53
10-07-2012 10:01:30
 Re: Flywheel in reply to buickanddeere, 10-07-2012 09:47:30
It came with directions and I read them and done as it said. Maybe its my luck.
buickanddeere
10-07-2012 10:45:58
 Re: Flywheel in reply to Deerepower53, 10-07-2012 10:01:30
??? Ok tell us exactly what you did to install the taper-loc.
Deerepower53
10-07-2012 11:51:11
 Re: Flywheel in reply to buickanddeere, 10-07-2012 10:45:58
I cleaned the crank of oil and put the taper loc on and got my end play right then put the fly wheel on put the nut on. Then started bumping it with the sledge hammer then tighting it over and over.
buickanddeere
10-07-2012 12:14:56
 Re: Flywheel in reply to Deerepower53, 10-07-2012 11:51:11
Hmmmmmm.......Will have to bump and tighen it more. How many lb ft of torque on the nut?
Deerepower53
10-07-2012 12:29:57
 Re: Flywheel in reply to buickanddeere, 10-07-2012 12:14:56
I took the fly wheel off and I'm going to start again. Not sure the lbs I used a big pipe wrench to tighten it.
