Rack and Pinion Choices?
S.D.L.
Which of these two have you used if either and how have they held up as far as quality etc.? Thanks!
You can tear anything up if you try. I use a rack and pinion from a pinto. Probably hard to find now. I don"t try to steer it if I am sitting still. I also just use 1/2 tool u-joints. Came in a 3 pack from Wally World.
The top one will work for a light weight tractor like a WC I am currently using one of them. The bottom one is heavier built and larger in size. Both are well built racks.
I like that idea for the 1/2" drive universals, checked Harbor Freight they have 'impact' universals for $7. I am putting a widefront wishbone off of a B on my WC.
