Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: 53 series Detroit
[Return to Forum]
VicS
09-22-2012 16:31:26
70.195.1.245
Have any of you guys changed from your high lift cam to the newer low lift cam. And if you did, does it make more power?. Has anybody changed to a 4 valve head and kept the old high lift cam? If you don't want to post on here, call me 618 838 2225. Thanks Vic
[Reply]   [No Email]
buickanddeere
09-24-2012 17:43:15
216.183.143.209
Re: 53 series Detroit in reply to VicS, 09-22-2012 16:31:26
618 area code, that far south in Illinois and so close to Kentucky. We had better write as I'll have problems understanding funny accents down there.
  [Reply]  [No Email]
VicS
09-25-2012 18:42:05
70.195.0.255
Re: 53 series Detroit in reply to buickanddeere, 09-24-2012 17:43:15
Thanks for the input. You are right in Canada this summer they did have a hard time understanding me. But I think the guy was speaking French.:) Vic
  [Reply]  [No Email]
buickanddeere
09-25-2012 18:48:37
216.183.146.134
Re: 53 series Detroit in reply to VicS, 09-25-2012 18:42:05
The French are an odd bunch and are a country unto their own inside the rest of Canada.
Canada was originally French Catholics from France pushed together with English Prodistants from Great Britan. Needless to say, there is still discent between the two groups several centuries later as they really don't mix or get along with each other.
  [Reply]  [No Email]
LCB
09-24-2012 16:28:20
67.142.167.24
Dont run down H you have stayed away from me all sumber.LOL
  [Reply]  [No Email]
VicS
09-25-2012 18:20:40
70.195.0.255
Re: 53 series Detroit in reply to LCB, 09-24-2012 16:28:20
Leroy I took off on a big trip and drove to Alaska this summer, took all of my spare change. Also the little JD isn't hitting as hard as it should. Just have pulled it three times all summer. It does all-right if the track is a little slick, but if it is tacky clay it powers out. I'm working on a dragon slayer motor for this winter. I think I will take the WC to West Alton. :) Vic
  [Reply]  [No Email]
bob7337
09-23-2012 16:37:49
64.12.116.199
If you want more power,check into gearing up the blower and going to bigger injectors. I know for a fact it can be done with factory parts
  [Reply]  [No Email]
VicS
09-26-2012 15:45:19
70.195.0.213
Re: 53 series Detroit in reply to bob7337, 09-23-2012 16:37:49
You can"t gear the blower up on a 1-2 or 3 cylinder. The blower runs off the timing gears. You can teflon coat it.
  [Reply]  [No Email]
bob7337
09-23-2012 16:32:27
64.12.116.199
How can a Detroit be a naturaly spreated motor? I thought all 53 71 and 92 series Detroits had a blower on them.
  [Reply]  [No Email]
buickanddeere
09-23-2012 19:36:01
216.183.143.209
Re: 53 series Detroit in reply to bob7337, 09-23-2012 16:32:27
It's written in black and white inside the DD service manuals. A non turbo two stroke is natural aspirated and a turbo'd two stroke is forced induction.
  [Reply]  [No Email]
Popinjohn
09-23-2012 17:51:44
24.168.43.43
Naturally aspirated refers to the action of atmospheric pressure filling the cylinder of a four cycle engine when the piston moves to the bottom of the cylinder on the intake stroke causing a low pressure situation in the cylinder. People refer to this as vacuum, but it really isn't, it's simply pressure lower than atmospheric, 14.7 psi.
This doesn't happen on a Detroit two-cycle because when the piston reaches the bottom both the ports in the bottom of the cylinder and the exhaust valves are open at the same time.
A blower is required, not to pressurize the cylinder like a turbo charger does, but is required to scavenge the spent exhaust gases from the cylinder and introduce fresh air for the next combustion event. Without a blower, atmospheric pressure in the air box and the exhaust manifold remain the same at 14.7, so no cylinder filling can occur. In other words, a Detroit won't run without a blower supplying pressure to the air box.
For lack of better wording, Detroit simply designates the two-cycle engines as NA (naturally aspirated).
  [Reply]  [No Email]
bgreer75
09-24-2012 19:11:29
70.195.0.221
Re: 53 series Detroit in reply to Popinjohn, 09-23-2012 17:51:44
Isnt speeding up the blower causing the air pressure inside the cylinder to rise above 14.7 causing it to no longer be naturally aspirated??
  [Reply]  [No Email]
buickanddeere
09-25-2012 08:16:05
184.151.63.193
Re: 53 series Detroit in reply to bgreer75, 09-24-2012 19:11:29
Look at the service specs in your 53 series service manual. The air box pressure is iirc under 12 inches water column of pressure .
Valves and piston ports are open at the same time.
Now if a turbo is added which causes exhaust back pressure, then airbox pressure will be measured in psi while under load.
Or if the cam timing is changed and/or sleeve port height is changed.
There are at least two different sleeve port heights for the 53 series.
There were 17 to 1 S engines. 19 to 1 turbo engines. 21 to 1 N engines. There may have been 25 to 1 military engines but they are considered some sort to proprietory military equipment not for public use.
  [Reply]  [No Email]
buickanddeere
09-25-2012 08:16:03
184.151.63.193
  [Reply]  [No Email]
4010 puller
09-23-2012 14:14:34
70.194.6.174
Vic:
Earlier (awhile back) you were asking about having blower work done. I think you were installing the new seal kit and teflon coating the rotor tips? Did you find anyone else that does this work other than Team Diesel?
  [Reply]  [No Email]
VicS
09-23-2012 19:37:37
70.195.1.10
Re: 53 series Detroit in reply to 4010 puller, 09-23-2012 14:14:34
No I never found anyone else that does it. But I think he farms out part of the work. I have a blower there right now getting ready for Princeton and Tunica.
  [Reply]  [No Email]
buickanddeere
09-23-2012 09:33:49
184.151.63.157
Only a high lift/high velocity cam on the 2-53 and two valve heads.
Now I just may know of a 2-53 with a four valve head crafted on and the high lift/high velocity cam. Equipped with the updated cam follower and valve springs. The springs don't bind but there is no flow advantage and over 2600rpm may float the valves. A waste of time and money vs the two valve head as is. If the cam had been reground then a different issue.
If in a rpm limited class use the two valve heads and high lift/high velocity cam with the last spring update.
Four valve engines first used a low lift/high velocity cam. Then the factory revised to a low lift/low velocity cam.
If no rpm limit then regrind the 2-53 cam to low lift/low velocity and use either two or four valve heads. With lots of spring pressure above factory pressure.
Try as one may, it's tough to beat a bored and stroked H.
  [Reply]  [No Email]
VicS
09-23-2012 19:57:42
70.195.1.10
Re: 53 series Detroit in reply to buickanddeere, 09-23-2012 09:33:49
Thanks for the information. I have a 4 valve head I would really like to try, but thought I should get the cam ground to the newest specs. My diesel guy says there is free horsepower there. I don't know. He admits no big difference in the flow on a bench. Just says they scavage better. I don't want to go over 2600. I have a boat motor dyno now. I am going to know what makes a difference, when I get it figured out.
  [Reply]  [No Email]
ChadS
09-23-2012 12:05:37
72.53.194.237
he did that all ready! now hes chasing Ms! lol. chads
  [Reply]  [No Email]
VicS
09-23-2012 20:16:16
70.195.1.10
Re: 53 series Detroit in reply to ChadS, 09-23-2012 12:05:37
Chad bring that H to Tunica along about the end of November. It-ill be a hoot. Vic
  [Reply]  [No Email]
4010 puller
09-23-2012 06:04:41
70.194.10.15
Isnt there one style cam they offered that was used when the 53 series engines were turning higher rpm"s(like 3800rpm, Naturally aspirated)?
  [Reply]  [No Email]
VicS
09-23-2012 20:07:28
70.195.1.10
Re: 53 series Detroit in reply to 4010 puller, 09-23-2012 06:04:41
My detroit guy, says the standard cam that came in my 2-53 is good for 2800 rated speed and will turn 3500 with no trouble.
  [Reply]  [No Email]
buickanddeere
09-24-2012 09:09:38
184.151.61.118
Re: 53 series Detroit in reply to VicS, 09-23-2012 20:07:28
Your DD guy has mixed up four valve 3,4,6,8 and 12 cylinder engines with the 2-53. Four valve engines were rated for 2800 but no two valve head engine was ever rated past 2400rpm. Have that in black and white in the DD manuals too.
Have to go with the low lift, low velocity cam and heavy springs to reliably keep the valves from hitting the piston. And to keep the valve train from floating.
Some guys over rev them for a while but but expect a wham, bang and , silence and smoke/ steam.
  [Reply]  [No Email]
ChadS
09-24-2012 05:38:12
72.53.194.237
vic, you got any use for a 420? freind of mine has one. block looks like it been worked on yrs ago, belive its stuck from sitting. i belive he wants around 1000 for it. i got a green tractor in here now. : )
  [Reply]  [No Email]
VicS
09-25-2012 18:30:05
70.195.0.255
Re: 53 series Detroit in reply to ChadS, 09-24-2012 05:38:12
Chad I would love to have it but, I have a D17 diesel project I have started and have stalled out on. I guess I'll have to pass. Vic
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
