Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Overbore affect on compression ratio ?
[Return to Forum]
6 cylinder puller
09-10-2012 17:31:40
71.31.183.158
was wondering what my compression ratio would be if I have 6.5 to 1 compression now and I overbored the cylinders .100ths
[Reply]   [No Email]
Indiana Ken
09-12-2012 18:38:01
66.249.234.244
 Re: Overbore affect on compression ratio ? in reply to 6 cylinder puller, 09-10-2012 17:31:40
1) Since you know the compression ratio, the chamber volume can be calculated given the bore and stroke of the engine.
2) The compression ratio resulting from the 0.100" over bore can then be calculated, using the chamber volume calculated in step 1).
You stated the engine bore is currently 4.5" can you provide the stroke dimension?
[Reply]  [No Email]
mlpankey
09-12-2012 14:45:21
152.85.8.33
I get 6.8 .1 Never give up cubic inches for anything . I know some will say bore causes detonation rod stroke ratio head flow the list goes on should limit cubic inches . the areodynamics of a buble bee technically says it cant fly but it does every summer day.
[Reply]  [No Email]
Dodgeit
09-12-2012 13:19:22
65.199.61.227
 Re: Overbore affect on compression ratio ? in reply to Dieselbear, 09-10-2012 17:31:40
Just giving an example the numbers are not actual. Lets just say that a 4.5" bore has 1948.4cc and a 4.6" bore has 2020.5 cc and the combustion chamber is 300 cc you would have the following compression ratios. I used a 5" stroke for my calculations. Flat top pistons with no valve reliefs just to keep it simple. Valve reliefs, head gasket height, piston down the hole @TDC, piston dome + or - and other things determine your heads compression chamber size.
4.5" bore = 6.49-1 this engine has 476 C.I. in 4cyl.
4.6" bore = 6.73-1 this engine has 493 C.I. in 4cyl.
Now if you add a decked head down to 250ccs you have 8.00-1 compression with a 4.6" bore and a 5" stroke, and 10.1-1 with a 200cc chamber and 4.6" bore 5" stroke vs. 9.75-1 with the same 200 cc chamber size and a 4.5" bore and 5" stroke.
[Reply]  [No Email]
Popinjohn
09-10-2012 20:19:45
24.168.43.43
With all other items left the same; head gasket; cylinder head; piston dome; etc. there would be a slight change in compression ratio.
This can be calculated by comparing the cubic inches before to the cubic inches after with the chamber volume of the combustion area. Compression ratio is the volume of the cylinder with the piston at the bottom of its stroke compared to the volume when the piston is a top dead center.
[Reply]  [No Email]
Dick W.
09-10-2012 18:56:12
69.40.243.176
That depends a lot on the size of the combustion chamber and the stroke of the crankshaft.
[Reply]  [No Email]
Dick W.
09-10-2012 18:57:20
69.40.243.176
 Re: Overbore affect on compression ratio ? in reply to Dick W., 09-10-2012 18:56:12
And the size of the original bore.
[Reply]  [No Email]
6 cylinder puller
09-11-2012 15:12:54
24.101.25.254
 Re: Overbore affect on compression ratio ? in reply to Dick W., 09-10-2012 18:57:20
bore before was 4.5 to 4.600 now
[Reply]  [No Email]
wHOcARES
09-10-2012 18:11:35
38.123.14.49
6.51:1
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
