| Tractor Pulling Discussion Forum |
Topic: farmall 340/traction
[Return to Forum]
| Author |
[Modern View]
| farmerjohn30
08-28-2012 16:55:57
142.68.114.252
I pull stock with a farmall 340, and can not seem to get any traction i pull in the 5,6,7000lb classes i have 11.4/36 tires with good tread and about 5psi air, i also run all wheel weights. it seems that i spin out every time even if i lower the engine rpm, i have all kinds of power that is not a problem, so does anyone have any suggestions?? |
| Dodgeit
09-05-2012 10:36:14
65.199.61.227
Re: farmall 340/traction in reply to Dave Thompson jr, 08-28-2012 16:55:57
| Quoting Removed, click Modern View to see
Anything that puts weight on the rear tires is a help. With that being said, loaded tires are a two edged sword. You need the loaded tires to weigh exactly the same, or the tractor will tend to veir off to one side. Their use on anything but a first or second gear pull would tend to hurt you in the long run. Wheel weights are far better. |
| Farmerjohn30
09-01-2012 12:40:46
142.68.114.54
Re: farmall 340/traction in reply to farmerjohn30, 08-28-2012 16:55:57
| What about loaded tires will that help ya or hurt ya? |
| Dodgeit
08-30-2012 11:21:25
65.199.61.227
Re: farmall 340/traction in reply to ERIC BENTON, 08-28-2012 16:55:57
As little as 2 lbs of air pressure can make a big difference. The other problem(s) you are fighting. Could be hitch height and placement, and lastly I studied long and hard about macking a 340 a puller and the thing that stopped me was the short wheel base of the tractor.
If your not floating the front end before spinning out, your hitch needs to move back some. I say that because you state that all your added weights are wheel weights. Once you get the front to start coming up you, may get competitive, with that short tractor.
To know when you have maximum traction (air pressure) for the tires, you need to look at the spin out tracks you made in the dirt, after you unhook.
If there is a flat mark in the dirt ( [ ) pressure is right on. If there is a U ( ( ) shape in the ther is a bit too much pressure. If the is a convex shape ( > ) you don't have enough air. Take the form in the middle of the parenthesies and rotate it 90 degs CCW to see what I mean. Each track is different and what works on one may or may not work there everytime.
Pulling is about balance and weight transfer and the right amount of traction, not so much about power. Too much power has a tendency, to hurt you rather than help you. At the end of the day the perfect set up has you running out of power or traction, just as you cross the 300 ft mark |
| farmerjohn30
08-29-2012 17:20:15
142.68.115.118
| thanks for the info, we are allowed 2 sizes over stock, so if i do not find any tires before next year i will try uping my psi, it could be my tire psi hurting me because a JD B is going past me and he has small narrow tires????? |
| super trucker
08-29-2012 01:58:25
173.130.2.195
| I would agree with kip. 8-10 to start may be up to 12psi. Also you would do better with a 13.6 on the back. 11.2 is a pretty skinny tire for what your doing. |
| LarryM
08-28-2012 21:47:51
76.208.67.171
| Look at what the people who are winning are doing and then compare your setup to the ones that win. I suspect they run bigger tires. |
| toolz
08-28-2012 20:26:45
206.221.154.149
| That sure isn't much tire for pulling that heavy. Can you go bigger? |
| Kip-Utah
08-28-2012 18:03:06
75.169.78.156
| I'd start by by upping your air pressure to 8 or 10 psi. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
