1950 A - miss under load
Anonymous-0
Last 2 or 3 pulls when load hits early or late on track(same thing happens when powerbraking)it misses,an pops back falls on its face. Changed carb,new wires,dis with new pickup. Fuel flow seems to be good.Coil is last part to change. Has ran 20yrs trouble free. 51 carb,big bore
power block,stock crank, high rpms.
ps-need help its the wife's puller.
thanks
Stephen
if you have a rubber fuel line and aftermarket inline fuel filter on it go back to a original type with a steel line.
points would cause this symptom or the condenser also. if it started all at once, i would suggest to change points and condenser and while you are in there, check to see if the distgributor shaft wobbles or is loose in the bushing.
