| Tractor Pulling Discussion Forum |
Topic: Lighten 77 oliver ????s
[Return to Forum]
| Author |
[Modern View]
| showdown
08-24-2012 19:15:19
75.194.243.33
Has anyone tried a lighten a 77 rc tub in any why, or fashion. If so how much weight can you get off Thanks...... |
| showdown
08-29-2012 19:08:41
75.213.191.138
Re: Lighten 77 oliver ????s in reply to MLPANKEY, 08-24-2012 19:15:19
| Nice looking 77, does yours have disc. brakes? I guess if I keep taken things off I will get in the 3500 class. Looks like you found a way, and still looks close to stock. Thanks for any help. |
| 6pack
08-29-2012 16:22:28
64.85.139.190
Re: Lighten 77 oliver ????s in reply to Mike n Mo, 08-24-2012 19:15:19
| Quoting Removed, click Modern View to see
Good Looking 77!!!!....What ya got under the hood??? |
| Del Anderson
08-26-2012 10:34:22
74.46.96.236
Re: Lighten 77 oliver ????s in reply to showdown, 08-24-2012 19:15:19
| You can go to weld on hubs and cut off your fender brackets and loose around 80 lbs. |
| pmer
08-25-2012 11:50:05
75.245.163.126
| | I didn"t think 77"s had two different tubs. The Super 77 has a little heavier tub. I can get mine in 3750 lb class pretty easy with about 150 - 200 lbs to move around. It has pressed steel on both ends, two smallish weight brackets. No PTO, belt pulley or hyraulics. If I take the weight brackets off I might get into 3500 pound class. So I suppose to go lighter you have to start using aluminum |
| Going to blow
08-25-2012 05:23:02
99.27.17.90
| Where are you at currently with the tractor weight and how light are you trying to get? What have you already done to lighten the tractor? Narrow or wide front, cast or pressed steel front and rear wheels, etc. |
| showdown
08-25-2012 07:55:05
75.194.243.33
Re: Lighten 77 oliver ????s in reply to Going to blow, 08-25-2012 05:23:02
| I have a 54 77 rc I want to get to 3250-3300 isb.I it has the heaver tub I known all the other things I have to do, but worred it will not be enought. 15.5x38 tires. |
| Going to blow
08-25-2012 12:27:04
99.27.17.90
Re: Lighten 77 oliver ????s in reply to showdown, 08-25-2012 07:55:05
| | Build a light weight wide (actually quite narrow) wide front end for it. Use a fabricated mounting plate for it with a rack & pinion steering system. Replace the stock steering shafts with hollow high strength steel tubing and light weight universal joints. When you down to the last few pounds, convert to hydraulic disk brakes. If that doesn't do it change to a steel flywheel & lose roughly 40#. You may find an aluminum radiator another good investment unless you are running a dry block engine. When all else fails, time to hit the gym and push away from the table early. |
| showdown
08-25-2012 18:13:35
75.194.144.140
Re: Lighten 77 oliver ????s in reply to Going to blow, 08-25-2012 12:27:04
| Thanks for the help, do you know how much it would cost to go to hydo brakes,and how much weight i would loose. where do i get a steel flywheel? Thanks.......... |
| baldwin racing
08-26-2012 07:50:46
74.79.154.169
Re: Lighten 77 oliver ????s in reply to showdown, 08-25-2012 18:13:35
| Larry, when i get a chance tonight i will look at the pics you emailed me......wide front could be an option but not shure how much total weight you will save but you would save some..... It was nice talking to you yesterday call me any time.....kelly baldwin |
| mm585
08-29-2012 10:41:28
166.182.3.21
Re: Lighten 77 oliver ????s in reply to baldwin racing, 08-26-2012 07:50:46
|  3500 pounds with a 180 pound driver and two 100 pound IH weights on the front. 16.9-38 BFG tires, band brakes with a super tub. solid axils, welded hubs, ect. The 880 olivers are down to 3500 so my 77 must be FAT! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
