Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Best White tractor for pulling
[Return to Forum]
MNoliver88guy
08-11-2012 19:42:30
173.140.136.179
I been pulling a 88 ollie and am wanting to get into the bigger turbo diesels. I hate seeing the same green and red tractors, so im thinking of a white, i know ill have more hurdles to jump to make a competitive tractor, but love the feeling of making the other guys eat their words and i like to stand out from the crowd, so any suggestions of what model works best, for mods and being able to make weight with out too much work? im a young puller, im 28 and been pulling the ollie for 7 years, so im bored. Keep in mind, i don"t have a huge budget. Thanks!
[Reply]   [No Email]
jerry4
08-13-2012 09:02:39
173.85.172.221
 Re: Best White tractor for pulling in reply to MNoliver88guy, 08-11-2012 19:42:30
i'm not trying to be a smart a$$, but if you want a"WHITE" pulling tractor ,go with a 70 sereis CASE. Alot cheaper,more cubic inches, and a 3 speed power shift.
[Reply]  [No Email]
MNoliver88guy
08-14-2012 18:09:09
70.13.15.141
 Re: Best White tractor for pulling in reply to jerry4, 08-13-2012 09:02:39
I just did some checking on the case 70 series, what is their down fall? is there alot of options to make more power? i found a few around my area for under 10 grand, im assuming im going to want a 1370 if possible?
[Reply]  [No Email]
180doug
08-12-2012 13:46:22
166.147.72.23
Someone dont have a good concept on pulling ! 20 grand getting started-- wow
[Reply]  [No Email]
6pack
08-12-2012 07:11:11
64.85.139.76
 Re: Best White tractor for pulling in reply to 4010 puller, 08-11-2012 19:42:30
I like them old Fords...wish more people pulled them!....Here in MI the turbo tractors have a few rules to limit turbo size, but are stilled bored, pump work, custom injectors, custom manifolds....in the 12,000lb class I have heard of 800hp+...It would be nice if a guy could pull 1 out of the field and pull, would have a higher tractor count for sure
[Reply]  [No Email]
dboll
08-12-2012 06:57:52
64.61.211.45
2255 Oliver-636ci of cat v8 with a matching turbo and a lighter non -planetary rear end if the rules allow
[Reply]  [No Email]
showcrop
08-12-2012 04:26:36
75.67.231.80
I have been pulling a Ford 9000 for about 9 years, and having a lot of fun with it. I have very little money in it. It had been in the weeds for seven years when I got it. It is really just a heap of junk with about ten thousand hours on it, pto has a bad bearing and pto clutch doesn't hold, but it is painted up with decals, and drastically lightened on the front and it is very competitive from 8500 up to 11,500. To get power with the Simms pump all you need is a screwdriver.
[Reply]  [No Email]
6pack
08-11-2012 20:37:12
64.85.139.76
 Re: Best White tractor for pulling in reply to GLR62, 08-11-2012 19:42:30
White 140 or 160 with a cummins.....It will be hard to compete if you have a budget, because a lot of turbo pullers do not have 1
[Reply]  [No Email]
johns
08-11-2012 20:37:46
69.163.7.60
What is your definition of a huge budget? Bigger tractors=more money. The tractor, parts, drivetrain, and transportation cost would all be considerably higher than pulling an 88. A fullsize White in decent condition would be at least $5k, Cummins swap at least $10k, then factor in another $5-10k for a heavy gooseneck trailer. From one Oliver puller to another, I know what you mean about wanting to surprise some red & the other green tractors. Just be aware that it would take at least $20k to start. If your ok with that, I think to make a White competitive you would need to swap a Cummins into a white 2-105 or 2-135. The tub would be wide enough for a cummins and the over/under can be built to handle the horsepower. If you want to be as light as possible go with the 105. It would be difficult to compete with the perkins or herc engines these tractors had from the factory vs. the 466 Deere's and IH's. What part of MN are you from? There are a number of cummins powered Olivers & Whites here in southern MN that pull sportsman & outlaw classes.
[Reply]  [No Email]
MNoliver88guy
08-11-2012 20:53:41
173.140.136.179
 Re: Best White tractor for pulling in reply to johns, 08-11-2012 20:37:46
Im from south central mn area, I was considering the 105, and putting a cummins in it, can you put the 8.3 in or is the 5.9 enough? The next question is would i be able to pull it, or do i need to re mark it as a 160? Or else just buy a 160, but they cost more up front and weigh alot more. you said the over under can be beefed up to handle the power? i know on the olivers that was always the thing that broke here on the farm.
[Reply]  [No Email]
gfs
08-12-2012 09:08:33
98.65.197.158
 Re: Best White tractor for pulling in reply to MNoliver88guy, 08-11-2012 20:53:41
Man the crazy talk on here, find a junked 1850 with the perkins tub get a cummins from a 95 or 96 dodge and your biggest expense is the steel flywheel and clutch. Remember just because somebody spent 20k doesn't mean you have too. Unless you are going super or pro stock the 5.9 can make a bundle of power very easily. Lock and load for maybe 10 unless you want all aluminum and never run before parts. Keep your eyes open and sometimes you can find one for sale. Was a heritage series for sale for 13k a while back. Good luck and it shouldn't be extremely difficult to make a competitive tractor.
[Reply]  [No Email]
MNoliver88guy
08-12-2012 12:23:28
70.13.221.25
 Re: Best White tractor for pulling in reply to gfs, 08-12-2012 09:08:33
the oliver 1850 still used the chain coupler to the over/under, and the whites went away from that. Is there a way to make a Oliver hold up to the extra power? I have found some 1850s for cheap, but i worry about durability. where can i find the conversion kit to put a cummins in a ollie or white, i know they are out there just not sure where to get one.
[Reply]  [No Email]
johns
08-12-2012 12:54:10
69.163.7.60
 Re: Best White tractor for pulling in reply to MNoliver88guy, 08-12-2012 12:23:28
There is a pull in Macintire IA(which is about 30 miles southeast of Austin MN) on Saturday August 18 at noon. They have two pulls a year which are well attended and organized. This pull there will be no speed limit. If you go I bet you will find at least 4-5 Cummins powered Olivers & Whites there. Check it out and don't be afraid to ask questions.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
