Case VAC 8 or 9 bolt hubs? Replacement fronts hubs?
Mopower
I have a Case VAC with 2" (?) axles and mismatched 28" rims. Is there a hub that bolts on either in 8 or 9-bolt? What about on the front spindles? Anything fit?
Your vac has 2 1/8" axles. A 22 massey harris will fit but they are real heavy and 9 bolt. A 300 case hub is 2 1/4" and would have to be shimmed and 8 bolt hubs. We just made a set for my oldest sons vac used pipe and split for the key and use another larger over the top with u-bolts didn't turnout too bad and are light. Check it out! The left wheel still had the massey hub on it in the last photo. We used a plasma cutter to cut the web out between the front wheel spokes. That lightened them up pretty good. Hard to see in last photo. Best of luck!
That is pretty genius and simple. I like it! I've heard they are a little shy on power. Did you warm yours up some?
I have a set of MH hubs if you are interested, $200 in St. Croix Falls WI. Call 715-825-four two three seven. Please no calls after 8:00 pm.
