Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Thinking out loud: Alternate 2 cylinder engine ideas.
[Return to Forum]
FactoryFarmer
07-21-2012 20:25:38
184.20.101.206
We don't have too many rules around here and nobody really cares too much about the rules as long as everyone has fun. Alot of people around have made some pretty bad 2 cylinders by thinking outside the box.
Couple things that have kinda crossed my mind.
#1 Intercoolers. Has anyone ever put one on a 2 cylinder? Would it make any difference? Colder air is denser so in theory is should make more power. I made a water to air one for my g. It draws air from the top of an insulated box which is filled with ice. I have been able to to lower the air temps by about 15-20 degrees. Tomorrow was supposed to be the first pull but I don't think there are classes for me so I'm staying home. Someday I'd like to try an air to air intercooler but I'm not sure about the effort to suck the air through the cooler.
#2 Meth Injection. I know alot of people that use it on diesel 2 cylinders but would it make any difference on a gas?
[Reply]   [No Email]
pmer
07-22-2012 21:51:29
75.234.63.211
 Re: Thinking out loud: Alternate 2 cylinder engine ideas. in reply to FactoryFarmer, 07-21-2012 20:25:38
How about a eight valve head?
[Reply]  [No Email]
FactoryFarmer
07-22-2012 19:55:13
184.20.101.206
I have a Murphys head already and it does seem to breath pretty good but it could be better.
As far as an even fire two cylinder I know it can be done but how long is that engine going to stay together when your trying to spin 2000 RPMs on a motor designed to go 900-1000?
Maybe if it's done right there is some merit to it. I found this pretty cool article a while back.
http://gasengine.farmcollector.com/Tractors/Twisted-Crankshaft-D-John-Deere.aspx
[Reply]  [No Email]
randy hall
07-22-2012 17:56:28
216.255.28.205
build a new crank and cam and make an even fire deere.
[Reply]  [No Email]
B-maniac
07-22-2012 18:54:06
97.85.62.26
 Re: Thinking out loud: Alternate 2 cylinder engine ideas. in reply to randy hall, 07-22-2012 17:56:28
With both cylinders being side by side that would mean both crank throws would be side by side and all the weight of both pistons and rods etc would be going forward or backward at the same time. Ballancing nightmare/impossible. One would be at tdc/firing and other tdc/exhaust/ that would be even fire in crank degrees of rotation. Won't work. Making a two stroke out of it with blower pressurizing through lower cylinder ports is only other way to get even fire out of a side by side common crank engine.
[Reply]  [No Email]
buickanddeere
07-22-2012 10:14:09
209.240.122.110
A billet aluminum cylinder head with huge ports
and valves and equipped with direct injection.
No hard to swap the injection system on from an
outboard motor etc.
[Reply]  [No Email]
B-maniac
07-22-2012 13:28:10
97.85.62.26
 Re: Thinking out loud: Alternate 2 cylinder engine ideas. in reply to buickanddeere, 07-22-2012 10:14:09
Kinda got to agree with B/D. JD,s have always had enough cu. in displacement but that lo-po cylinder head is incapable of feeding it. A "G" for example is over 400 cu in. Might make 50 hp at around 1100 rpm. I don't care if ya go to 2000 rpm with stock head ain't gonna make much diff. Any other 400 cid motor will make easy 100 hp at 2000. Someone would cast a "good" alum head with spark plugs and individual intake runners along with good flow runners and valved angled slightly towards centerline of cylinder one might feel more like building for more cu in. The 2 cyl side by side design does have it's limitations also. Would end up being very expensive fun indeed.
[Reply]  [No Email]
dboll
07-22-2012 08:28:52
64.61.211.134
about .090 overbore and a point of compression would do about as much
[Reply]  [No Email]
Loosehandle
07-21-2012 21:15:53
174.231.136.3
How about 2 stroke conversion?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
